Bent Valves on $50 engine, now with pics
Old Jun 5, 2008 | 09:28 PM
TOOSTUBBORN2FAIL's Avatar
TOOSTUBBORN2FAIL
Default Bent Valves on $50 engine, now with pics
So i picked up a DOHC engine for $50 from a guy who said it wouldnt run. Figured even if somethings seriously wrong at least i could probably scavenge something.
Turns out the timing belt snapped. Exhaust valves are bent, although there not bent all crazy, just barely, intake valves seam fine, the exhaust valves are stuck about 1/4 inch from seated.
Questions, are the valve guides replaceable? I'm thinking that he wasnt going that fast for only the exhaust valves to be bent, everything else on the head is perfect, the cam journals are perfect, car only had 73000 on it, and its been sitting ever since.
Old Jun 5, 2008 | 11:03 PM
jfink's Avatar
jfink
Default RE: Bent Valves on $50 engine
the guides are replaceable, but probably don't have the equipment to press them out and press the new ones in. Now would be a good time to rebuild and check the rest of the engine out. Make sure everything else is kosher
Old Jun 5, 2008 | 11:38 PM
fsu182's Avatar
fsu182
if not rebuild then just buy a used cylinder head and get an upper gasket set and move on.
Old Jun 6, 2008 | 04:51 AM
TOOSTUBBORN2FAIL
ya, this ones for my engine build, so im not rushed, and the machine work isnt a prob, this engine was going to be fully rebuilt and sent to AMM for porting, it'd just be a shame to waste it with that low of mileage and damn near perfect cam journals, cool i just wanted to find if the valve guides could be replaced, hadnt had a chance to pull them out yet
Old Jun 6, 2008 | 10:41 AM
TOOSTUBBORN2FAIL
Old Jun 6, 2008 | 01:15 PM
12 volt's Avatar
12 volt
yup, just tame it to a machine shop and they will change them out. by the way, the larger valves are for intake
