upgrade alternator
Old Jun 6, 2008 | 12:45 PM
opie9797's Avatar
opie9797
Default upgrade alternator
i want to upgrade my alternator but what amp i have and what amp i need to find is a mystery to me does any one have any small tricks to help
Old Jun 6, 2008 | 01:44 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: upgrade alternator
Upgrade your alternator? You want to over charge you battery or something? Get a smaller pulley on ur alternator. Then it will spin faster. But there should be no reason to upgrade the alternator. Its just a waste of money enless your running major amps or something that drains alot of power.
Old Jun 6, 2008 | 11:48 PM
12 volt's Avatar
12 volt
these guys might have one for neon but you have to find a dealer near you.
http://www.stingerelectronics.com/
you need to add up the fuses and thatwill tell you how many the amps the amplifiercan pull.
you really shouldent need a better alt unless you running some serious audio or lights.
Whats in your setup?
Old Jun 7, 2008 | 01:14 PM
opie9797's Avatar
opie9797
i got xenon 9007 headlights competion 12 sub punch 500 amp flex fision flip down tv
Old Jun 7, 2008 | 03:41 PM
12 volt's Avatar
12 volt
try using a capacitor first
http://www.caraudiohelp.com/newslett...citor_myth.htm
Old Jun 7, 2008 | 04:40 PM
opie9797's Avatar
opie9797
a capacitor would work but if i could get a bigger amp alt from a junk yard for half the price i would go that way im cheap
Old Jun 7, 2008 | 05:22 PM
12 volt's Avatar
12 volt
tell me if you find one. stinger might be the only one
Old Jun 8, 2008 | 10:43 PM
das2123's Avatar
das2123
ORIGINAL: opie9797
I think you would be fine, but spud is the expert on audio/visual.
Old Jun 8, 2008 | 11:03 PM
jfink's Avatar
jfink
I've heard that the PT cruisers alternator has the same casing but puts out more amps. anybody know anything about this???
Old Jun 9, 2008 | 01:51 PM
Ghost Neon 2's Avatar
Ghost Neon 2
This sucks
