tach problems
Sounds like a loose gauge cluster. You ever to try and give it a push? Make sure the slips are tight. If that helps That i would remove it, clean it up and make sure it mounted tight. I had the problem on a few of my neons.
or take the whole thing off...take the black peice off that tells you what the bulbs are for take the board off...and there are 2 rows of 5 solders...one on the left side and one on the right...re solder those...mine has been working fine ever since
ORIGINAL: Captansavaho
sohc 2.0
ebay intake
shop straight pipe
1/2 3 hours
1/4 1 day
and still takin' honda badges
