code 11 crank pos. sensor
Old Jun 21, 2008 | 03:05 PM
krimson's Avatar
krimson
Default code 11 crank pos. sensor
Getting code 11. circuit has proper voltage. went to junkyard and got 2 crank position sensors. One didnt let it start up but the other did. I let it run for 3 minutes then i shut it off to to move onto other things like tighten up the power steering belt. I then did a set up to charge the A/C, when to went to start it up it wouldnt start up (cranking but no ignition). checked my codes again and there it was again, code 11. i pulled the sensor back off and cleaned the connections and reinstalled and still the same result. Anyone have this happen to them? Any suggestions? Is this a common neon problem?
Old Jun 22, 2008 | 09:26 AM
spudsterier's Avatar
spudsterier
Default RE: code 11 crank pos. sensor
you might have a bad wire sumwhere or a problem with the pcm
