SRT-4 Turbo on DOHC head
Old Jun 22, 2008 | 01:35 AM
RiceRocketEater's Avatar
RiceRocketEater
Default SRT-4 Turbo on DOHC head
I have a SOHC cam right now but i was hearing some things around like if i put a DOHC head on a SOHC block it lowers the compression then i hurd that the SRT-4 turbo bolts right up to it no problems.
is all of this true?
Old Jun 22, 2008 | 02:09 AM
12 volt's Avatar
12 volt
Default RE: SRT-4 Turbo on DOHC head
yes
Old Jun 22, 2008 | 09:20 AM
spudsterier's Avatar
spudsterier
the turbo will bolt right on, but there is also a hell of alot of toher stuff you will need to do...
the stock exhaust wont bolt onto the turbo though
Old Jun 22, 2008 | 09:54 PM
Ghost Neon 2's Avatar
Ghost Neon 2
The neon dohc head has larger exhaust ports, which will help with power. Just get a manifold off ebay, or have a local tig weld you a tubular manifold.
Old Jun 23, 2008 | 05:53 PM
mmench's Avatar
mmench
ORIGINAL: spudsterier
use the srt cat pipe after the down pipe and it should fit pretty well to the stock exhaust... will have to use a coupler to hook the together though
