clutch
Old Jun 26, 2008 | 06:18 PM
krtrsdg0's Avatar
krtrsdg0
Default clutch
were can i get a good clutch and light wait fly wheel for not an arm and a leg lol
Old Jun 26, 2008 | 06:38 PM
95to96transplantneon's Avatar
Default RE: clutch
do you have a modular or non-modular clutch...
Old Jun 26, 2008 | 08:18 PM
krtrsdg0's Avatar
krtrsdg0
Default RE: clutch
I have a modular clutch and can you use a non modular clutch in it?
Old Jun 26, 2008 | 09:28 PM
moparmandjh's Avatar
moparmandjh
Default RE: clutch
Newb question... Whats the difference? I was told mine has a Centerforce dual friction clutch, would like to know what I'm looking at to verify. Sorry about the hi-jack.
Dave
Old Jun 26, 2008 | 11:24 PM
krtrsdg0's Avatar
krtrsdg0
Default RE: clutch
oh its all good we have ?'s lol
Old Jun 27, 2008 | 04:21 AM
Default RE: clutch
modular are built as one part... the flywheel clutchplate and cover are all rivited together as one, and are bolted on to a flex plate witch has the starter gear on it... When installing this type of clutch you insert the the clutch in the transmission case then put the transmission on the block then threw the inspection plate on the bottom of the transmission bolt it to the flex plate that has allready been bolted to the crank
Non-modular are all parts seperate... fly wheel is bolted to crank then you have to aline the clutchplate and cover and then bolt it all together. then slide the transmission over everything. The flywheel itself has the starter gear...
