Help 95 neon 2.0 sohc misses at idle
Old Jun 29, 2008 | 07:39 PM
lost_and_confused's Avatar
lost_and_confused
Default Help 95 neon 2.0 sohc misses at idle
My 95 Neon just started to miss every once in a while at idle and sometimes while driving also. Sometimes it does not have any problems and runs just fine. There are no codes in the computer. I replaced the fuel filter and that did not fix the problem. I don't know what to try next. I don't have the money to keep replacing things till I find out what is wrong. Can anyone give me some idea's
Old Jun 29, 2008 | 10:39 PM
brushedchrome's Avatar
brushedchrome
Default RE: Help 95 neon 2.0 sohc misses at idle
Keep it simple at first. Check plugs, wires, electrical connections.
Old Jun 30, 2008 | 12:19 AM
XenonNeonSport's Avatar
XenonNeonSport
Its probobly like every other neon ive ever seen, mine does it all the time and has since I got it. Ive heard if you get Magnacore plug wires it will help but I dont know for sure. It sounds like you're just talking about it 'putting' at idle? What helped mine the most is running high test ethanol fuel like from Appco if you live around the Applachian area or Gas n Go at a Food City plaza if you have one. Mine stopped for a year when I did this but I cant afford it anymore lol Good luck with it, hope this helps.
Old Jun 30, 2008 | 10:27 AM
das2123's Avatar
das2123
ORIGINAL: brushedchrome
X2....the neon is sensitive to corrosion on the battery terminals.
Old Jul 1, 2008 | 10:12 PM
lost_and_confused
thanks for the suggestions. It turned out to be just a loose battery cable. Once I tightened the cable all problems went away. Thank you again
Old Jul 2, 2008 | 08:35 AM
das2123's Avatar
das2123
Glad to hear it was something simple.
