Neon wont f'in start
Old Jul 6, 2008 | 04:06 PM
lateralus823's Avatar
lateralus823
Default Neon wont f'in start
So i bought a new fuel pump last week, ran fine , this week i drove 10 hours on thursday go to start it friday it wont start so i figured it was the started bought a new started it wont ****ing start, what could it be now?
Old Jul 6, 2008 | 04:27 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: Neon wont f'in start
So your not even getting the motor to crank? Sounds like the ignition module thing may be out because its not sending a signal to the starter.
Old Jul 6, 2008 | 05:52 PM
lateralus823
No the motor wont even crank over, when i first tryed it after the long drive it would at least turn over but not it just clicks.
Old Jul 6, 2008 | 06:15 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
sounds like dead battery. have you tried jump starting it?
Old Jul 6, 2008 | 06:20 PM
lateralus823
Yeah i used my truck then a battery charger and still nothing.
Old Jul 6, 2008 | 06:48 PM
neonracer1010's Avatar
neonracer1010
bad battery?
try putting the battery out of your truck in it if it will fit
Old Jul 6, 2008 | 06:51 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Sounds like either a bad battery, bad connection, or bad ground, or possibly even a combination of those. Pick up a battery post cleaner, clean up the posts, tighten up the cables, and see if it will start.
