1998 Dodge neon A/C
Old Jul 13, 2008 | 12:47 PM
qsilver182's Avatar
qsilver182
Default 1998 Dodge neon A/C
I have a neon and brought it in to Car X to get the A/c recharged. After charging the compressor would not kick on when it was running of just the car. When they hot wired it it worked fine. They ended up getting a new switch fuse for it but that didn't work. They ended up telling me that it could be the pcm. Does any one have a clue if that could be right because i dont want to change the cars computer just because they "think" its that.
Old Jul 13, 2008 | 12:56 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: 1998 Dodge neon A/C
I didnt know that ecu controlled a/c? There is a relay in the fuse box inside the car. You checked that?
Old Jul 13, 2008 | 01:34 PM
qsilver182's Avatar
qsilver182
They replaced the relay under the hood and it would still only kick on when hotwired directly to the compressor. They said the ecu/pcm what ever grounded the ac compressor and when it was supposed to read 0 volts it was still reading 12. I just think that it is kind of odd that i would have to replace he whole computer
Old Jul 13, 2008 | 02:46 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
yeah i dont think the PCM controls the A/C compressor at all.
Old Jul 13, 2008 | 09:42 PM
bone33's Avatar
bone33
you could always wire it direct and put a switch inside.
Old Jul 13, 2008 | 10:08 PM
I_Ride_Neon
Did you check the relay in the car? Its right under the fuses. I think its the one closer to the firewall. It says on ur fuse cap.
