97 neon sohc timing belt check list
Old Jul 15, 2008 | 04:43 AM
edacsfan's Avatar
edacsfan
Default 97 neon sohc timing belt check list
There is a timing belt kit on ebay right now that seems very complete. The question is... is this overkill or exactly what I need to get her done right? Its for a no frills 97 plymouth neon with sohc motor 110K miles on it
for $225 bucks you get
This auction is for a new Timing Belt,
Tensioner, Idler, Hydraulic Tensioner, VC Gasket set,
Cam Seals, Crank Seal and Water Pump for:
Avenger, Neon, Sebring, Talon, Eclipse, Spyder
2.0L (1996cc) 4 Cyl. DOHC (420A) 95-99 Non-Turbo
This Kit Contains:
• Timing belt
• Water Pump w/gasket
• Idler, Tensioner and Hydraulic Tensioner
• Crank seal
• Valve Cover Gasket
• Cam Seals
• 4 Spark Plug Seals
[IMG]local://upfiles/91741/F41EEEB5D8324D62BBFB11476DA80769.jpg[/IMG]
Old Jul 15, 2008 | 10:04 AM
spudsterier's Avatar
spudsterier
Default RE: 97 neon sohc timing belt check list
it isnt bad, but all you NEED to do a timing belt is the timing belt, water pump, and tensioner pulley.
you could get just the needed pieces for $75 or less from autozone
when you replace the timing belt, there is no need to change the valve cover gasket or spark plug tube seals unless they leak and the hydraulic tensioner hardly ever go bad...
another problem, you said your car is a sohc...the list and pic are for a dohc
Old Jul 15, 2008 | 08:14 PM
das2123's Avatar
das2123
I got my parts from www.rockauto.com. Good quality parts.
