Shifts Into Neutral when going into overdrive
Old Aug 12, 2008 | 06:37 PM
Footer4321's Avatar
Footer4321
Junior Member
Default Shifts Into Neutral when going into overdrive
Hey all, I have a 1995 Plymouth Neon Automatic that is shifting into neutral when it kicks into overdrive. It does not do it all the time, just once every 4-5 times that it really hits the accelerator. Is this a common problem/is there a fix that does not involve a re-build?
Old Aug 13, 2008 | 02:16 PM
das2123's Avatar
das2123
There is no overdrive on the neon transmission.
Check your fluid level and adjust your kickdown bands.
