F***ed speaker wires-explane
Old Aug 13, 2008 | 12:45 PM
RiceRocketEater's Avatar
RiceRocketEater
Default F***ed speaker wires-explane
i have a wired question i wanna no if any ones elses is like this
i pulled up a wireing diagram for the car(mitchell on demand) it says left front door speaker says green is + and brown is - that was fine thos where the wires that where their so i go to the other side and it says that violit is + and dark blue/red is - but i pull the speaker out and there is a green and a brown im F***ing confuesd is any one elses like this its a 96 high line
the back of the deck has all the proper coulous on it tho
Old Aug 13, 2008 | 07:49 PM
RiceRocketEater
help asap
im putting in a head unit 2moro and there are 2 wired (dimmer and head lamp in) i need a dimmer one for the head unit im assuming that ill use the dimmer wire
but what do i do with the other one leave it blank
Old Aug 13, 2008 | 11:24 PM
12 volt's Avatar
12 volt
buy a wiring harness
http://www.soundoffaudio.com/item.cfm/id/519
these have all of them labled
