? on advancing timing with comp cam stage 2
Old Aug 14, 2008 | 01:11 PM
roush24's Avatar
roush24
Default ? on advancing timing with comp cam stage 2
I have a 96 sohc motor that just had the head shaved and a 4 angle valve job. Also at the time it had a comp cams stage 2 cam installed. It has a fidanza adjustable cam gear and I wanted to know if anyone knew what the safest maximum degrees it should be advanced?
Old Aug 14, 2008 | 02:39 PM
12 volt's Avatar
12 volt
you should really only change cam timing if your tuning with a dyno.
only way of know of finding the "safe max" would be by claying the engine.
http://www.c-speedracing.com/howto/claymotor/clay.php
Old Aug 14, 2008 | 02:47 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Yea I would not adjust the timing without a dyno. It will either turn out to be a waste of time, you will break something, or you have a slight chance of being lucky and gaining power off it. If you want timing advanced get a mopar ecu or afx ecu.
