this is getting annoying
Old Aug 20, 2008 | 10:16 PM
bigjo1990's Avatar
bigjo1990
Exclamation this is getting annoying
ok so i decided to try to put in an aftermarket cd player in a plymouth neon i have a wiring harness to make it easier but this one also has another ground its not the braided ground but it hooks directly into the back of the factory radio i tried to hook that wire into the back of this cd player but it wont power on i know this wire is wat is causing all my troubles but i dont know wat to do about it help me if you can pictures or detailed instructions will be very helpful
Old Aug 20, 2008 | 11:31 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
make sure your antenna is also pluged in and check the fuse. some headunits use the antenna as a ground.
Old Aug 21, 2008 | 11:50 AM
bigjo1990's Avatar
bigjo1990
o i plugged that in too and ive chacked the fuse for the radio and the fuse in the cd player imma have some pros look at it prolly i got the audio cables and amp turn on wire waiting to go but the cd player is the hold up
Old Aug 21, 2008 | 08:40 PM
DustDevil33's Avatar
DustDevil33
If that ground has a plug, just rig up some sort of connector and attach it to any piece of metal in the dash framework. That should fix it I hope. Let us know how it turns out
