how are you...
suppose to be able to see how much anti-freeze is in your car because its in the back and i cant tell i know its clean because i just had a water pump put in but is there anyway i can relocate the coolant tank so i can see how much coolant is in there?I have a 95 plymouth neon ..just in case you didnt know thanks for all the help i can get
whats wrong with putting it in the trunk
https://dodgeforum.com/forum/images/icons/icon10.gif
well now that i think about it pressure is exerted equally and undiminished. So you would be able to put it in your truck.
you could try and build a sight guage so you can see the coolant. just make sure you use a high temp hose.
hose
http://www.rubberfab.com/hose_sight_gauges_idx.html
genral idea
http://hbd.org/cdp/sightga/sightga.htm
