Intermittant speedometer
Old Sep 8, 2008 | 10:02 PM
das2123's Avatar
das2123
You don't have to add solder, but sometimes it helps.
Old Sep 9, 2008 | 09:19 PM
buenymayor's Avatar
buenymayor
I haven't popped the cluster out yet, but will this weekend. Resoldering the connectors correctly isn't a problem. I've been an electronics tech for 25 years. I'll pop the cluster out this weekend and have a look see. Thanks for all the suggestions!
Old Sep 9, 2008 | 11:47 PM
das2123's Avatar
das2123
You should be able to do it blindfolded then.
Old Jun 4, 2009 | 03:01 AM
buenymayor's Avatar
buenymayor
I finally got around to popping the cluster out. Cracked solder joints like some of you have said. Works like a champ now. Thanks!
