battery fuse
Old Sep 5, 2008 | 05:45 PM
rickav's Avatar
rickav
Default battery fuse
Since my battery is in the truck anyone have any ideas what size fuse i should use in the trunk, or what is the max draw for the starter?
Old Sep 5, 2008 | 09:11 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
well I dont know if i would use a fuse i would look more into getting a 50-100 amp circuit breaker.
Old Sep 5, 2008 | 09:14 PM
neoncrazy101's Avatar
neoncrazy101
i would just hook up the battery like it normally would in its stock location...cept with longer cables.
Old Sep 5, 2008 | 11:07 PM
rickav's Avatar
rickav
I was thinking 100 amp bus fuse, I can mount terminals on both end. If I get a short under the seat or hood somthing i want somthing to burn in half before the #2 gauge wire I used.
Old Sep 6, 2008 | 03:01 AM
DOHCgarrett t3
you would want the fuse within 12" inches of the battery.
Old Sep 6, 2008 | 09:55 PM
rickav's Avatar
rickav
it will be bolted to the positive battery post
Old Sep 7, 2008 | 11:00 AM
spudsterier's Avatar
spudsterier
100amp should work fine....a bus fuse would work good, but an ANL fuse would work better and you can get the ANL's is pretty big sizes...i had a 300amp ANL for my old stereo in my neon
