head bolts
Old Sep 6, 2008 | 08:03 PM
rickav's Avatar
rickav
Default head bolts
I want to swap heads, on my 95 to my 96, the 95 just had a valve job, do I need to change the head bolts? If I do, why?
Old Sep 6, 2008 | 10:39 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Head bolts stretch when torqued. rule of thumb you should change them every time the head is removed. but, spud stated before they are designed to be used a second time; after the second time they should be replaced. Same is true with the connecting rod bolts; but they can ONLY be used once.
