95 neon fuel filter leak
Old Sep 9, 2008 | 02:57 PM
yesac's Avatar
yesac
Default 95 neon fuel filter leak
Good site fellows, Changed fuel filter in daughters 95 neon in the dark and when i tried to start it and checked for leaks it was pouring from the supply tube to engine, in the day time i found rubber O rings on ground, Put them on and it still leaks, THE QUESTION IS in what order do these go Thanks
Old Sep 9, 2008 | 11:51 PM
12 volt's Avatar
12 volt
so your leaking fuel from the supply line to the engine?
Which filter did you change the strainer on the pickup tube or regulator/filter?
Old Sep 10, 2008 | 10:54 AM
yesac's Avatar
yesac
just changed the filter outside the tank, this one does not have a regulator, the hose connection that feeds the engine leaks, the car was sputtering like it was running out of gas, and if i kicked in passing gear it would run fine untill i let off of it, start spurttering again,
Old Sep 10, 2008 | 11:12 AM
12 volt's Avatar
12 volt
ahh yes 95.
Here is a pic
http://www.autozone.com/shopping/rep...00c15280079281
its the round oil filter looking thing with the three hoses coming out. 97+ have a sticker on it that says fuel accumulator not serviceable. i think the 95 and some 96 had the external filter
i really dont think the fuel lines should have O rings on them. most look like this
http://www.autozone.com/shopping/rep...00c1528007928d
if it keeps leaking i would just cut it off and use some fuel injector hose and clamps
your fuel pressure reg on the 95 is mounted inside the tank
http://www.autozone.com/shopping/rep...00c15280079277
Old Sep 10, 2008 | 01:37 PM
yesac's Avatar
yesac
Thanks 12 volt, thats what i needed to know, Any idea what would make it act like it was running out of gas and when you kick in passing gear it runs fine??? let it out of passing gear and it sputters again
Old Sep 10, 2008 | 04:03 PM
12 volt's Avatar
12 volt
hard to say for sure. change your plugs and try and run some injector cleaner
Old Sep 10, 2008 | 04:32 PM
yesac's Avatar
yesac
I'll do that and let you know
