which one?
Sep 9, 2008 | 07:13 PM
which one?
crane or zex cam ?
Sep 9, 2008 | 10:17 PM
Sep 10, 2008 | 12:18 AM
Crane has 5 choices, Zex seems to be limited to the Xr series which says something like 14hp gain.
i would try and find an 2002 neon RT in a juck yard and pull the magnum cam for cheap. assuming you have a SOHC engine
Sep 10, 2008 | 09:15 PM
is that a better cam then both of the cams i listed?
Sep 10, 2008 | 11:18 PM
Quote:
Originally Posted by
12 volt
The 01 cam is slightly more agressive.
streetracer88
No it isn't, just cheaper but a nice upgrade. You would need magnum springs as well.
I'd go with the Crane cam if you can afford it. You also need upgraded springs as well.
