compression?
Old Sep 14, 2008 | 12:00 AM
3rd white's Avatar
3rd white
Default compression?
does ne1 know what the stock compression ratio is for the 2.0l dohc? im gonna rebuild da bottom end and need to know what im lookin 4. if its 10.5 im just gonna do da bearings and call it a day. if not i might go with da whole rebuild kit.
Old Sep 14, 2008 | 12:21 AM
Jyro's Avatar
Jyro
9.8:1 if its 02 older. 03and up are 9.6:1.
Old Sep 14, 2008 | 12:22 AM
Jyro's Avatar
Jyro
thats only dfor the sohc, MY BAD
Old Sep 14, 2008 | 12:57 AM
12 volt's Avatar
12 volt
direct compression check should be around 190 PSI
Old Sep 17, 2008 | 10:53 PM
sabin420's Avatar
sabin420
95-99 is 10.5:1
Turbo, 8.1:1
