Need 99 R/T door panel blue driver side
Old Sep 16, 2008 | 11:56 PM
l33tn3wb3r's Avatar
l33tn3wb3r
Default Need 99 R/T door panel blue driver side
I have the stock blue design on my interior fabrics. Door panels are impossible to find!! I'll be a happy boy if someone has a driver side door panel in my color they would sell me
Old Sep 17, 2008 | 10:25 PM
unclemike's Avatar
unclemike
You didn't say what happened to your door panel so I'll guess it came apart at the riveted seams. My daughters did the same. I repaired it using fiberglass cloth and resin from Bondo. While I was at it I used JB Weld to repair the door pull. The bottom where the screw goes thru pulled apart. I found a small washer that fit exactly into the round indentation, or well, the mounting screw goes into and glued it in. I first glued the broken part back on and waited until it had set up then glued the washer in. I did the washer trick on the passenger side door pull though it wasn't broken. You could see that it was stressed. Then I switched them side for side, the door pulls are the same for right and left, so the better (stronger) one was on the driver's door.
The only thing I would have done differently was lay a sheet or a towel on the work surface because I put some rub marks on the door panel.
