2.4 last minute questions.
Old Sep 19, 2008 | 12:17 AM
iwalton63's Avatar
iwalton63
Default 2.4 last minute questions.
alright so i am about to start buying everything i need for the 2.4 swap.
I have found a stratus motor for like 700 in town. so i think i am going to pick that up.
but first i have a few questions.
1. If i buy the stratus motor do i need the Alternator bracket from the stratus, or the Alt brackets from the PT cruiser? or are the same?
2. If i got the stratus motor do i need the water outlet tube from the stratus or Pt? or are they the same?
3. And same thing with the power steering bracket. stratus or Pt. or are they the same?
4. And i am assuming that i need a new water pump,thermostat for the 2.4 right?
and is it worth it to put the 2.0 cams in there or no?
5. and also you do need the 2.0 underdrive pulley. not the 2.4 right?
Old Sep 20, 2008 | 12:09 AM
iwalton63's Avatar
iwalton63
nobody?
Old Sep 20, 2008 | 12:15 AM
das2123's Avatar
das2123
1. PT cruiser alternator brackets...PN#'s 4891533-AA upper, 4668445AA lower
2. PT Cruiser water inlet neck and o-ring...PN#'s 4884291AA neck, 6503180 O-ring
3. 2001 - 2002 PT Cruiser Power Steering bracket
4a. Use the thermostat housing from the 2.0.
4b. Use the 2.0 DOHC cams
5.Yes, use the 2.0 UDP
Old Sep 20, 2008 | 03:06 AM
iwalton63's Avatar
iwalton63
thanks man just what i needed.
Old Sep 20, 2008 | 11:19 AM
unclemike's Avatar
unclemike
A good rule of thumb is get as much stuff with the motor as they will let you have. You never know when it will come in handy.
