1000cc injectors...only 3 work?!?!Help
Old Sep 21, 2008 | 08:12 PM
SohcBigTurbo's Avatar
SohcBigTurbo
Exclamation 1000cc injectors...only 3 work?!?!Help
I purchase 4 1000cc low-impedence injectors about 2 years ago in anticipation for the neon I am almost done building, the only problem is that only 3 of them work. I read 2.6ohms on 3 of the injectors with my multimeter and 13.2ohms on the one that wont fire. Now I know that these are brand new 1000cc injectors. anybody have any imput as to why the 4th one is reading like a high-impedence injector, but wont fire, even when hooked up without a resistor-box? This is frustrating the shyznyt out of me. I am supposed to have this car running full boost by friday for my first shakedown pass at the dragstrip....
Old Sep 21, 2008 | 09:09 PM
spudsterier's Avatar
spudsterier
did you try swapping the injector around with another 1 of the 1000cc injectors??? if it still doesnt work in a different port then you just have a bad injector...if it does work in a different port, then there is a wiring problem
Old Sep 22, 2008 | 02:47 AM
SohcBigTurbo
nah..its the injector this sux, now I have to wait 2weeks for a new one....
Old Sep 22, 2008 | 10:13 AM
Jr. Mechanic's Avatar
Jr. Mechanic
Put some stock ones in for the time being, assuming that is all you are waiting on.
Old Sep 23, 2008 | 04:16 AM
SohcBigTurbo
.....I cant turn the wastegate down below 15psi..... this is my "race car" so I dont need to daily drive it
