95 dodge neon 2.0 engine swap help
maybe its just me, but i had problems with the ac compressor hitting the front of my car. if you have ac i suggest taking the ac compressor off before you try to pull it entirely out of the car. and if you ARE pulling instead on dropping, id suggest an engine leveler. we had to tilt the hell out of the motor and trans to pull it out. but it went smooth after that.
practice makes perfect. second time i pulled it, it was a piece of cake.
Its easier to drop it out the bottom. I pull the tranny with the engine when I do it. But if you plan to just pull the engine you will need to get it out the top. Yea neon engines are one of the easiest engine swaps. Not very many wires or hoses like hondas and what not.
