Seafoam help please
Ok. So I want to Seafoam my car. How do I go about doing it? I know that you can put it in your gas tank, but I want to run it through the inside of my engine. I read somewhere about sucking it in through a vacuum line? Is this correct? If so which line can I use? I have a feeling the engine I swapped in is dirtier than hell, and I want to clean the inside up as much as I can.
I did search and didn't really find the info I was looking for. Thanks for the help.
. Although this probably doesn't help much, there aren't that many tubes you can pull off in that general area, so experiment a little. I learn as I go so im not a hardened neon mechanic yet
