noise in front end?
Old Oct 24, 2008 | 07:05 PM
streetracer88's Avatar
streetracer88
Default noise in front end?
when i turn the wheel to the left i hear a grinding noise and idk what it is any suggestions its only when i turn left is this a sign that my drive axel is going bad at 66k?And i got out and looked at it with the wheel turn but cant see anything i thought the sway bar broke but i guess it didnt cuz i dont see anything hanging any help is greatly appreciated thanks
Old Oct 24, 2008 | 08:25 PM
streetracer88
and i just noticed when i go over bumps it does the same thing any help please???
Old Oct 24, 2008 | 10:56 PM
neoncrazy101's Avatar
neoncrazy101
could be a wheel bearing. when u jack up the car, try to move the wheel up and down (rocking it) and if it rocks up and down then i would say the wheel bearing. does the sound get worst as u speed up?
Old Oct 25, 2008 | 03:40 PM
dirt_trac_racer_80jr's Avatar
The wheel could b rubbing ...pull the wheell and look around 4 a shiny spot wher the tires hittin ....it might clear when it just sitten ther. But when ur movin and turn the wheel will lay over and flex...it just a thot
Old Oct 25, 2008 | 03:48 PM
streetracer88
ya right now there is 195/75 r14's on it and they wear out fast so that could most likely be the problem?
Old Oct 25, 2008 | 07:54 PM
neoncrazy101
yeah, those tires are big... OEM is 185/65/R14 or 175/70/R14
Old Oct 25, 2008 | 08:21 PM
streetracer88
so could that do damage?
Old Oct 27, 2008 | 08:05 AM
das2123's Avatar
das2123
Well if you think about it....if the tire is rubbing, then you are either wearing down the tire quickly or it's could blow out on you.
Old Oct 27, 2008 | 12:35 PM
streetracer88
ok so i think i should go bk down to the 185/65 r14's all round again
