tap knocking noise
Old Oct 25, 2008 | 08:26 PM
Heavy_D508's Avatar
Heavy_D508
Default tap knocking noise
ight well, i had a funny noise for a long time and would like to do something about it, i think its my valves making that tapping noise which i hope it is, does that mean i have to adjust the valves? if so does any one knows the specs for it? i have a feeler gauge if that needs to be used for it, i know how to use it, i do it on my toyota alot, but would like to know the specs for the intake and the exhaust valves.
Old Oct 27, 2008 | 08:12 AM
das2123's Avatar
das2123
More than likely it's your lifters making the tapping noise...not your valves. If the ticking increases with RPMs, then that is your possible culprit.
Old Nov 3, 2008 | 06:29 PM
Heavy_D508's Avatar
Heavy_D508
yea sometime the noise will go with the rpm, do i have to adjust something?
Old Nov 4, 2008 | 10:09 AM
das2123's Avatar
das2123
You can take a look at your lifters and see if any are cracked or possibly loose.
Old Nov 4, 2008 | 07:36 PM
Heavy_D508's Avatar
Heavy_D508
well if its loose what can i do? is there anything for me too do? like adjust it?
Old Nov 5, 2008 | 08:15 AM
das2123's Avatar
das2123
Torque them down.
Old Nov 6, 2008 | 12:37 AM
ohioguru's Avatar
ohioguru
check to make sure your spark plugs are tight. air might get around them makes same sound. one of mine got lose and i thought it was the same thing. never figured that would ever happen though. i was told by firestone that my head was warped and it would cost 1200 to fix, turns out a spark plug needed a turn of the wrench when i started messin with stuff.
