Need help passing emissions...96 Neon O2 and EGR not ready
Old Nov 11, 2008 | 08:27 PM
atxjax's Avatar
atxjax
Default Need help passing emissions...96 Neon O2 and EGR not ready
What could this mean guys? Maybe the car isnt hot enough? Bad thermostat?
Old Nov 11, 2008 | 10:24 PM
12 volt's Avatar
12 volt
how do you know o2 and EGR are not the problem?
Old Nov 12, 2008 | 10:08 AM
atxjax's Avatar
atxjax
Good question......i dont but its funny how both systems are not ready. meaning they have no input going into them.
Old Nov 13, 2008 | 11:57 AM
das2123's Avatar
das2123
If you recently disconnected the battery, it takes the PCM about 50+ miles before it shows them ready for testing.
Old Nov 15, 2008 | 06:03 PM
atxjax's Avatar
atxjax
Driven past 50 miles already. I noticed that the temp gauge only goes up about 1/4 of the way. Is it supposed to be at half?
Old Nov 15, 2008 | 06:51 PM
12 volt's Avatar
12 volt
thats what mine does, Half way means something isnt right.
Old Nov 15, 2008 | 07:21 PM
atxjax's Avatar
atxjax
ok.....so its not the thermostat. Im out of ideas as to what it is. All the emissions systems are not ready.
o2, egr, catalyst. Car has been driven more than 300 miles already. weak battery? weak fuel pump?
Old Nov 18, 2008 | 06:37 PM
p8ntballa113's Avatar
p8ntballa113
My car got that code when i dropped my engine in... My egr sensor plug was broken, so i just took the plug off and connected the wires manually to the female end and it fixed everything... when that plug was not connected my speedometer didn't work and my car stalled a lot.
Old Nov 21, 2008 | 11:28 PM
atxjax's Avatar
atxjax
Thats the thing. I have no codes stored. When I check for codes I get a 55 which means there is nothing stored.
Im out of options as to what to do at thi spoint. Im gonna just have to start testing and replaceing all the sensors. Can someone who's had this problem before please chime in?
Old Nov 22, 2008 | 03:05 AM
12 volt's Avatar
12 volt
Okay first of all what state are you doing the test in?
Have you already failed a test, and if so what were the results(what part did it fail)?
