Oil leak please help
Old Feb 10, 2005 | 12:49 PM
chud298's Avatar
chud298
Default Oil leak please help
I have a 1998 Neon R/T. Last summer I had a very small oil leak which I thought I fixed with the replacement of a new PCV valve. But now it's back and I have no clue where it could be. It's a very small leak and it's taken about 2700 miles for all the oil to be completely gone. If you can help me in any way...please do. The head gasket was replaced about 10,000 miles ago. I think I've tried everything, and I know it's NOT blowing past the rings becasue I'm not blowing any smoke out the pipes
[IMG]local://upfiles/12287/914296FC3A794287BCB9B1D07E224893.jpg[/IMG]
[IMG]local://upfiles/12287/AB886D9953324760A07383CA704D740C.jpg[/IMG]
Old Feb 10, 2005 | 12:58 PM
suprtrooper's Avatar
suprtrooper
Default RE: Oil leak please help
Did You double check the coolant?
Old Feb 10, 2005 | 12:59 PM
chud298's Avatar
chud298
I've never heard that, what would that do???
Old Feb 10, 2005 | 01:03 PM
suprtrooper
The oil can get in to the coolant. Check the color of the water in the radiator.
Old Feb 10, 2005 | 01:04 PM
chud298's Avatar
chud298
So how would that be fixed with a gasket or somethin'?
suprtrooper
What are the pictures you are trying to post?
Old Feb 10, 2005 | 01:10 PM
suprtrooper
Ya, but if you are lossing all your oil that might not be it. Is there any oil on the engine or oilpan ?
Old Feb 10, 2005 | 01:12 PM
chud298's Avatar
chud298
Well after about 2800 the engine light came on real quick. I thought I was seeing things becasue I swear I had fixed it. I checked the oil and there was absolutly in there!!!
Old Feb 10, 2005 | 01:20 PM
suprtrooper
I would check the water to see if there is any oil in it. Check the oilpan plug & oil filter for leaking oil. I lost all my oil from a falty oil filter one time. If you are loosing that much oil you will see it some where.
Old Feb 10, 2005 | 01:26 PM
chud298's Avatar
chud298
That's the problem. After I noticed that there was nno oil, I changed my oil completely, oil filter and all. I contiuously check it and I don't see oil ANYWHERE.
