cranking but wont start
Old Nov 22, 2008 | 11:43 AM
beernutz1983's Avatar
beernutz1983
Default cranking but wont start
it is cranking over but its the biggest pain to get it started i have checked so much wiring replaced the battery im getting fuel... i guess all im trying to say could it be the ignition coil?
Old Nov 22, 2008 | 12:23 PM
beernutz1983
o ya 99 neon by the way
Old Nov 23, 2008 | 12:46 AM
neoncrazy101's Avatar
neoncrazy101
Timing? Starter?
Old Nov 24, 2008 | 05:43 AM
kabuk1's Avatar
kabuk1
check your EGR valve. if its dirty or worn out it can cause rough idling and keep your car from starting altogether. my car(also a 99) did the same thing yesterday & my EGR ended up being the culprit. its the little sensor-like plugin thingy attached to the intake & a new one runs about 80-90 bucks at auto zone. you can take the top part apart & clean it & get a bit more life out of it but its best to just replace it. also, did you check your spark plugs?
Old Nov 24, 2008 | 04:25 PM
12 volt's Avatar
12 volt
how do you know your getting fuel?
have you tested for spark yet?
http://www.toolfetch.com/Category/Au...lfetch&cm_ite=
Primary coil resistance should be .45-.65 ohms whitch is the coil at the connection. lookes like this( - - -) center is B+ while right is 2-3 left is 1-4 coil. test secondary at the output tower top thou top, bottom thou bottom should be 11K ohms.
