Oil seepage from Camshaft position sensor area.
Old Nov 24, 2008 | 09:45 AM
atxjax's Avatar
atxjax
Default Oil seepage from Camshaft position sensor area.
Was underneath the car this weekend and noticed it was covered in oil. I traced it back up and found the source to be from right around the camshaft position sensor area.
Does this mean I need a new sensor or is there a seal that i can replace?
Old Nov 24, 2008 | 10:09 AM
spudsterier's Avatar
spudsterier
there is a small round seal on the sensor...these things leak all the time
Old Nov 24, 2008 | 10:15 AM
atxjax's Avatar
atxjax
Thanks for the reply. Does that mean I need a whole new sensor? Or can u get the seal separately?
Old Nov 24, 2008 | 07:15 PM
atxjax's Avatar
atxjax
called my local stealership. They have the O-ring separately for less than 5 bucks out the door. Im planning on slapping one in and at the same time use a thin bead of high temp silicone to make sure it seals good.
Thanks for the help all.
Old Nov 25, 2008 | 12:01 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
your best bet is to go to the hardware store for the o-ring. the seals are made in all shapes and sizes and are much cheaper than the stealerships prices.
Old Nov 26, 2008 | 01:09 AM
das2123's Avatar
das2123
Yeah, but for about $5 ain't bad at all for a seal that is from the factory.
Old Nov 26, 2008 | 03:12 PM
Jr. Mechanic's Avatar
Jr. Mechanic
But... You cant tell me you don't feel like you are getting raped when you pay $5 for a tiny rubber seal.
Old Nov 26, 2008 | 07:30 PM
spudsterier
$5 is $5....if it stops the oil leak then why not...
if i needed one, i would just get it from autozone or the dealership
Old Aug 23, 2013 | 03:59 PM
Footent's Avatar
Footent
Go spend an extra 4 bux for a poorer seal. You got good advice, which you asked for; use it.
Peace
Old Aug 23, 2013 | 04:03 PM
das2123's Avatar
das2123
Peace
Well seeing how the post is 5 years old, I would think he has already made his decision.
