drum brake help please
Old Nov 25, 2008 | 07:42 PM
fsu182's Avatar
fsu182
Default drum brake help please
can someone give me a crash course in neon drum brakes? any advice on how to get the drum off?
Old Nov 25, 2008 | 07:51 PM
12 volt's Avatar
12 volt
use some pb blaster or any kind of penetrating oil on the wheel studs. then hit it a couple times with a peice of wood.
http://www.autozone.com/shopping/rep...00c1528007969d
Old Nov 26, 2008 | 12:57 AM
das2123's Avatar
das2123
Rubber mallet works also.
Old Nov 26, 2008 | 04:20 AM
12 volt's Avatar
12 volt
remember to turn e brake off
Old Nov 26, 2008 | 08:26 AM
GLXRustang's Avatar
GLXRustang
yeah to get that drum off try beating on the face top then bottom back and forth
make sure to do one side at a time, that way, if you get lost on what goes where you can refer to the opposite side. If its your first time, i suggest a manual.
