Whining noise from intake....
Old Dec 7, 2008 | 12:41 PM
djberneski's Avatar
djberneski
Default Whining noise from intake....
I recently just replaced the head gasket on my 96 SOHC Highline. I heard a whining noise from the #4 intake port, when ever I hit around 2300 rpm. I do have a bad EGR and no vacuum lines are connected to the EGR. Can somebody give me a clue on what it could be please?
Old Dec 8, 2008 | 09:48 AM
GLXRustang's Avatar
GLXRustang
How can you tell its from the #4 intake port? And by whining does it whine or whistle? Also more importantly, when does it do this, at idle, at WOT or while revving? Does the sound change during any of these events???
Maybe try a leak-down or compression test and check your vacuum at idle with a gauge...
Old Dec 8, 2008 | 01:18 PM
djberneski's Avatar
djberneski
I can tell thats its coming from the #4 intake because when i hold a stethascope to it, its the only port thats making a noise. it only does it while revving, and the sound stays the same.
Old Dec 9, 2008 | 08:07 AM
GLXRustang's Avatar
GLXRustang
thats weird, theres nothing that i know of that whines inside of an intake port
Old Dec 9, 2008 | 10:40 PM
djberneski's Avatar
djberneski
i thought the same thing. i know the egr valve is bad, but i dont know if it would whine.
Old Dec 10, 2008 | 10:32 AM
GLXRustang's Avatar
GLXRustang
It is back by the 4th cylinder, but if siphons off the exhaust, not intake. If it's stuck anyways, just replace it. If you block the EGR, the ECM will know and throw alarms, I know cuz I did it and got sick of the alarm, plus, I didn't notice any change in performance. Hell if it doesn't fix it, just return it and say you didn't install it cuz you didnt need it!
