battery light on
Hello,
I have a 1995 Dodge Neon. Since we changed the starter, Wednesday, the battery light is switched on continuously. You tell me: alternator, it is thought, therefore, have returned the alternator (still under warranty, as nine of March), it is defeated in all tracks, and he said he had nothing, he have changed the c state like the code said(ignition key). The alternator load 14.2. Then have thought a computer and was tested 3 computer but the fact is same. We have check thread, same thing, fuse, same thing. 3 mecanician analyzing the car and found none.
If you have an idea, thank you very much!
next to the battery the is a batt temp senor, if it unplugged or something is wrong it will do the CEL and the batt light.
Is your check engine light (CEL)on??
have you done the key dance?
Yes I bet they removed your battery tray when the did the starter. And didnt hook the sensor back up. If thats not it I would check the connections on the starter. I think the alternator charge wire runs from the alternator directly to the starter. So if it wasnt installed correctly it can cause charging problems which will throw a battery light.
Hello,
No the check engine no light up, and the oil light is off too.
I will said to my father(mecanician) to check the starter, it him there have install it. I found the starter don't do the same sound of the older starter i have, when i start. So, i will check it, and let you up to date, if you have other idea...
Thank
p.s. sorry for my bad english, i am french and not england
Thank
yea i would check the battery temp sensor which connects into the bottom of the battery tray because i ran into the same problem and come to find out it was just unhooked good luck and hopefully that solves your problem
