mtx leaking fluid
Old Dec 24, 2008 | 09:54 PM
chief135smitty's Avatar
chief135smitty
Default mtx leaking fluid
thought it was the half shaft seals so I replaced them and it is still leaking. It looks like it is coming from the clutch area. Is it possible to have the input shaft leak? I can not find any other place that is leaking. Anyone have any suggestions?
thnks
Old Dec 24, 2008 | 11:55 PM
spudsterier's Avatar
spudsterier
how badly is it leaking?
Old Dec 25, 2008 | 12:45 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Its coming from inside the bellhousing? And it is tranny fluid right?
Old Dec 25, 2008 | 02:23 PM
chief135smitty
It is tranny fluid and it's coming from the bellhousing. Have you heard of that before? I just replaced the engine and it did not leak before I started.
Old Dec 26, 2008 | 04:39 PM
I_Ride_Neon
Yea there is a shaft seal in there, if I remember correctly. It usually dont leak from the input shaft seal, from what I have seen. And how much does it leak? Chance you may have damaged housing.
