No power to ignition coil HELP!
Old Jan 1, 2009 | 03:03 PM
JesseP's Avatar
JesseP
Default No power to ignition coil HELP!
Im having kind of a problem, the relay for my fuel pump wasn't receiving power, had to rewire that. And after i fixed that i found out my ignition coil isn't getting power... Trying to figure out why... My engine would turn over and everything, just wasn't getting fuel.
Is there any way i can rout my power to the ignition coil strait from my battery? Or how else can i fix it?
Old Jan 2, 2009 | 08:21 AM
das2123's Avatar
das2123
Did you happen to check your fuel pump/ASD relay first?
Old Jan 3, 2009 | 10:50 AM
JesseP's Avatar
JesseP
It all turns out to be the computer...
