Goddamn Car
Old Jan 12, 2009 | 08:56 PM
  #21
chenzo's Avatar
chenzo
went out there last night after work, the charger had been on it for a couple hours, turned the key and nothing. Im probably going to go back out there in a few minutes and pull the starter off, whats the easiest way to take it off? I have the dual fans, would it be best to remove the one fan for the time being?
Old Jan 12, 2009 | 09:04 PM
  #22
ajpranger's Avatar
ajpranger
i just changed my starter out last week and i found that if i dropped the front motor mount it made the starter a lot easier to access. however i only have the one radiator fan so i don't know anything about that.
Old Jan 13, 2009 | 12:30 PM
  #23
weatherman212's Avatar
weatherman212
While I find it easiest to remove both fans then the starter, You might want to try to jump start it, or change the battery; because if the battery is bad, sticking it on the charger will do nothing. The battery will not hold a charge, and thus you are just wasting time (and money on your energy bill).
Old Jan 13, 2009 | 08:34 PM
  #24
chenzo's Avatar
chenzo
checked connections, all good. gotta go look at an r/t for my buddy so im going to go back out there and try to jump it later.
