Rear Discs!
Old Jan 13, 2009 | 05:14 PM
neon527's Avatar
neon527
Default Rear Discs!
I've been doin some research and i cant seem to find any info, my question to you guys, is what other car besides the sport model neons, can i take the rear disc setup from? I tried cross referencing part # for rotor and pads of a stratus of the same year and they seem to be fairly the same setup when i went to the local junkyard, any info would be helpful thanks!
97 neon 4dr
Old Jan 14, 2009 | 01:01 PM
12 volt's Avatar
12 volt
mainly R/T's, ACR's, and some sports..all depends on if the car had disk brakes as an option. i found mine in on a 95 sport
Old Jan 15, 2009 | 07:57 AM
das2123's Avatar
das2123
Done the swap a few times and never been disappointed with the results. Discs look so much better than drums, even if they don't improve braking quality.
Old Jan 16, 2009 | 08:15 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
sure thing Das, also the pads are so much eaiser to change.
