wheel fitment
Old Feb 3, 2009 | 04:38 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
less off set will work but they will stick out the side, and rub on the outside wheel well. If, the offset was higher than 40; you would need a spacer or not mount the tires at all. all this is assuming the lug pattern is the same.
Screw the hammer, you need a wrecking ball.
Old Feb 3, 2009 | 04:42 PM
sabin420's Avatar
sabin420
aww hell...he pullin out the big boy
