Camm quest
Old Feb 6, 2009 | 11:25 AM
98/\/eo/\/'s Avatar
98/\/eo/\/
Default Camm quest
I am thinking about buying cams for my 98 neon DOHC, I havent put an aftermarket cam in any thing befor and so I am asking for advice as to what I should look for.
I wold like to run my power band about 4 to 7
In the future I wold like to turbo the car, like in a couple years or maybe longer Idk. does that change what sort of cam I would want?
Old Feb 6, 2009 | 06:09 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
crane #14 cam or equevalant if you plan on turboing later.
Old Feb 6, 2009 | 10:25 PM
Spawne32's Avatar
Spawne32
http://cranecams.com/pdf/Page170.pdf
Old Feb 7, 2009 | 09:34 AM
spudsterier's Avatar
spudsterier
crane 14's are awsome
Old Feb 8, 2009 | 05:11 PM
98/\/eo/\/'s Avatar
98/\/eo/\/
alright, thanks! In the link provided by Spawne32 they mention ignition applications is that stuff neccicary for the cam swap or is that just stuff they recomend?
Old Feb 8, 2009 | 07:06 PM
Spawne32's Avatar
Spawne32
the only thing necessary for the cam swap is the titanium valve springs and retainers
Old Feb 8, 2009 | 08:46 PM
sabin420's Avatar
sabin420
do not install the cam without the valve springs and retainers...more than likely your stock valve springs are a little worn, but that's not the issue...with the new cam, it will be opening the valves further and the stock springs will not allow that. When I installed my cam, I decided to check with the stock springs. They WILL bottom out without the new valve springs...so, Valve springs is a must.
Old Feb 9, 2009 | 07:00 PM
98/\/eo/\/'s Avatar
98/\/eo/\/
Ok, thanks, that anwers all my questions.
