Gravel Tires Sizes and Lift and Brakes...
Old Feb 13, 2009 | 09:28 PM
cum4acummins's Avatar
cum4acummins
Default Gravel Tires Sizes and Lift and Brakes...
I was wondering what size gravel tire to use and I have 15 so what will fit? I was thinking on doing the 2nd gen upgrade on suspension but upon further investigation I found out the PT from 02 and newer would work. I wanted the suspension and brakes so I would have 11" brakes. Aren't the PT and Neon the same? So couldn't I get the parts from a 02 or newer neon and have the same brakes? Because I am using the spring and struts how much would I gain in suspension lift for rally?
