how much boost
Old Feb 22, 2009 | 04:11 PM
rockenuptown's Avatar
rockenuptown
wait i read on the site where i bought it and it says nothing about not being able to use it on a turbo app y cant i use it
Old Feb 22, 2009 | 05:38 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Well I am sure it says no advanced timing. And your ecu advances timing. You need your retard your timing for boost.
Old Feb 22, 2009 | 06:09 PM
rockenuptown
ok but cant i just get the timing retard
Old Feb 23, 2009 | 03:20 AM
I_Ride_Neon
Yea with msd or something. or megasquirt. Just run a stock ecu and a missing link/map clamp and you should be fine.
Old Feb 23, 2009 | 09:45 AM
spudsterier's Avatar
spudsterier
the mopar pcm advances timing.......its not as simple as just retarding the cam timing..
you have to use a different pcm..
the stock bottom end can saftely handle 8 psi without issues
a rough estimate for HP when it comes to boost, 1psi = 10hp
it gives you a rough estimate
Old Feb 23, 2009 | 10:43 AM
GLXRustang's Avatar
GLXRustang
the mopar and AF/X pcms state that they shouldn't be used with turbos because of the advanced ignition timing the computers use, thus the need for high octane premium fuel. You don't want the mopar pcm. You want to give it to me. (mind control)
Old Feb 23, 2009 | 02:12 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
i do not have a first gen but i run 8psi on a stock block... but i am also a second gen...
Old Feb 24, 2009 | 02:41 PM
ottoretto's Avatar
ottoretto
y he cant? bro i gonna suggest sumthing, try to get air/fuel mix meter cuz if u dont have enough fuel u blow the engine, and put a 3" pipe, if u have better flow better performance!
Old Feb 24, 2009 | 09:55 PM
I_Ride_Neon
^^Wideband o2 gauge+o2=air/fuel meter
