my neon build up all opiouns needed please check out
Old Mar 22, 2009 | 02:31 PM
12 volt's Avatar
12 volt
megasquirt would be nice with this setup since it can control all of your accessories and add the fuel when its needed.
Never heard of anyone use both ML and MC so i couldnt tell you
Old Mar 22, 2009 | 10:21 PM
rayraydoet's Avatar
rayraydoet
wha if i get and inline fuel pump that goes p to 100 psi and i used my fuel regulator and raised the fuel poressure realy high with stock injectors and have it rise a psi every psi of boost . hat should work for now. until i can get a mega squirt AND build it and make a hanress for the engine. do yo know any one selling a mega already built and maybe with a harness already made?
Old Mar 22, 2009 | 11:19 PM
sabin420's Avatar
sabin420
I find Eagle I Beam Rods to be a little stronger than the Crowder...the head from Howell, you are better off taking the one you have and taking it to your local race shop to have them do the porting for you.
Old Mar 23, 2009 | 06:19 PM
12 volt's Avatar
12 volt
that will work, i was just thinking about when you add the N2O.
Old Mar 23, 2009 | 07:59 PM
rayraydoet's Avatar
rayraydoet
i got seprate regulator for the n20 n a full computer controled nitroous system stat of da art shiznit lol the n20 is just for an anti lag systm so i get full powr off the line
Old Mar 23, 2009 | 08:09 PM
12 volt's Avatar
12 volt
ooh yeah i forgot to mention where you could find assembled MS.
http://www.diyautotune.com/catalog/m...058a277936591e
http://www.symtechlabs.com/catalog/m...-ecu-p-32.html
Old Apr 7, 2009 | 06:08 PM
rayraydoet's Avatar
rayraydoet
i love soldering im very good at it. im solder mirco circuits before realy tiny flat resitors transitors and so on. im guna build one custom im going to make the old harness plug and play and build a bleprint of it and build them from scrach and sell them to who ever wants one ill garentee they work if i sell them toany one they will be tested im guna buy stuff in mass so i can get all the componts cheap and make the boards f i want to buy bulk for cheaper and sell the assembled for alot cheaper my budy has a machine that makes boards in 1 min it all compter solder bed i bring him a board he will mas produce it for mad cheap assemble megasuirts for the price of 100$ or less. or ill build them to make it cheaper it dont matter i love doing this stuff so i want ot build a bunch if my first seup works out ll good ill make them then. so you guys think i should use the relay board or do direct harness i was guna do harness i dont see a point in the relay board unless i can have that to and use it to turn stuff on for me
