any tips on install?
Old Mar 24, 2009 | 09:44 PM
streetracer88's Avatar
streetracer88
Default any tips on install?
I am going to attempt to install my r/t cluster tomm is there any tips or tricks for taking the old one out and to make it easier?Any help thanks
Old Mar 24, 2009 | 10:37 PM
sabin420's Avatar
sabin420
Yank straight up on the dash cover, pull it out torwards you, and you got 4 screws in each corner of the cluster. take the screws out and pull straight back till it pops out. Dash pad is just quick clips and the electrical connection doesn't even have a clip on it, you just push the new cluster in and screw down. push the dash cover back then hit the top to reconnect the quick clips. shouldn't take but 2-3 min.
Old Mar 24, 2009 | 10:58 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Best tip there is, to have a magnet stick ready. The bottom left screw is a pain to get back in.
Old Mar 24, 2009 | 11:47 PM
streetracer88
that sounds easy enough ill let ya know how i make out with it tomm thanks
Old Mar 25, 2009 | 09:37 PM
streetracer88
I Did the swap and it litterally took me 2 mins to do thanks for the help that was the first time i ever switched clusters out so i thought it would be hard but i guess not
Old Mar 26, 2009 | 07:46 AM
das2123's Avatar
das2123
Did you swap odometers to keep the mileage correct?
Old Mar 26, 2009 | 05:48 PM
streetracer88
everything stopped working on the cluster a long time ago so the last thing the odometer said was 143,xxx so i dont know how many miles are really on the car it could have 200k for all i know lol...but the new odometer says 160,xxx i have no idea how to find out how many miles were on it tho
