Fuel injector question
Old Mar 4, 2005 | 11:18 AM
chud298's Avatar
chud298
Default Fuel injector question
Does anyone know the stock fuel injector cc's are in a 1998 R/T, and also how big is the biggest it can go
Old Mar 4, 2005 | 09:22 PM
casper's Avatar
casper
Default RE: Fuel injector question
I believe its 17lb if I am correct. You can definatly put in bigger injectors, but if you are not sucking in the air to match the fuel you are putting in the motor, they are no good.
Old Mar 8, 2005 | 05:41 PM
RT_Driver's Avatar
RT_Driver
They are 19lbs. stock. If you want to get bigger ones with what you have it wouldn't be a good investment. You will be flooding your engine with fuel and have no way to control it. Until you get into some big mods. like turbo or high comp. I'd stay away from them.
I ran my 2.0 DOHC on the stock injectors with crane 16's and 10.5:1 comp. with a fuel controller. Get one of those if you want to improve performance. Then when you go to the drag strip you can adj. you fuel to match your car.
Old Mar 8, 2005 | 09:58 PM
casper's Avatar
casper
New, unclogged injectors, if yours are, will help. I have also hear something about I believe the accels, that they are better than stock even at the same size.
