3 inch exhaust
Old Apr 1, 2009 | 07:47 PM
rayraydoet's Avatar
rayraydoet
Default 3 inch exhaust
guys help me out i want to put 3 inch exhhaust iw as guna ether run it straight back put a tip in the middle of my bumper so i had a pefectly straght exhaust for the best power what do you think? or my other optuion was to make that right turn thwen go straght out the side of the tire ether in front of the tire or behind it where ever it runs. what do you guys think about that?
Old Apr 1, 2009 | 09:33 PM
GLXRustang's Avatar
GLXRustang
wait are you turbocharged too? or planning on turbo? cuz unless you have boost, there's no gains with such a large exhaust. And if you are turbocharged, backpressure increases lag, so I'd go with a 3.5" exhaust, you'd spool 500 rpm sooner
Old Apr 1, 2009 | 09:34 PM
GLXRustang's Avatar
GLXRustang
Oh and straight out the middle with an large oval tip, rar rar rar
Old Apr 1, 2009 | 09:35 PM
sabin420's Avatar
sabin420
straight back won't work...you got the rear frame in the way, and in front of the rear tire is a bad place too...curb your car once and you bend the pipe...best would to be to run in the stock location...rear drivers side is best.
Old Apr 2, 2009 | 12:31 AM
spudsterier's Avatar
spudsterier
3.5" on a neon? WTF?!
even with a turbo, there isnt much use for an exhaust bigger then 2.5" on a neon
Old Apr 2, 2009 | 01:06 PM
12 volt's Avatar
12 volt
i vote for 3in, with high flow muff out the side
Old Apr 2, 2009 | 10:11 PM
rayraydoet's Avatar
rayraydoet
i agree 3 inch right out the side scr*w the stock location i want to be differnt ha lol
im doing hi flow matlic cat cutout, 1 inch fles pipe i m guna flange my cat to mke it removable so i can put test pipe in. im guna use a morso spril race pipe with maybe a resonator tip or regular tip, and im guna wrap the hole exhaust from the front back major scavinging
