valve cover gasket
Old Apr 5, 2009 | 06:31 PM
streetracer88's Avatar
streetracer88
Exclamation valve cover gasket
do you put rtv silicone on the valve cover gasket before putting it on?
Old Apr 5, 2009 | 07:50 PM
streetracer88
i didnt use it as i was told by some friends that it sits inside the valvecover about a 1/4 a inch and that it will offset the gasket and it would blow out in a week so thanks anywayz
Old Apr 5, 2009 | 09:09 PM
Altima_wb's Avatar
Altima_wb
you shouldn't need to sometimes a tiny bit in the corners just to hold it in place as your installing it is fine but you don't need to put it around the whole thing...
Old Apr 5, 2009 | 09:29 PM
sabin420's Avatar
sabin420
I use it to hold it in place...thin film of it across the whole gasket does best...makes it very sticky
Old Apr 5, 2009 | 09:55 PM
streetracer88
lol....i couldnt remember with my last neon if i put rtv i prolly did but it seems like my last neon and this neon have different valve covers but they were both plymouth sohc the other one i had before was a 95 idk if that matters but it seemed like that valve cover was different and it had a bracket for the coil pack but the 95 was also a highline if that matters?this is a 96 and the coil pack bolts right up to the valve cover unlike the other neon but i couldnt remember i just got so much stuff going on at once lol..
Old Apr 6, 2009 | 09:38 AM
spudsterier's Avatar
spudsterier
the valve covers are different between the 95 sohc and the 96 sohc
Old Apr 6, 2009 | 04:37 PM
streetracer88
why are they different?I thought 95-99 neon engines were all the same with different computers?
