brake pedal problem
hey guys when i push my brake pedal down my right blinker goes on but stays on doesnt blink when i put the right blinker on it blinks but with it on and i push the pedal down it makes the like stay on nad not blink. i cant figure out hte problem. its realy annoying i cant get the car inspected until that is fixed i changed the relay and flasher. im not sure why the blinker turns on and stays solid but both blinkers work
its in the bulb or the wireing.. usually means the bulb is bad... might still work... i just went threw this on my neon ended up being the bulb it still worked but for some reason after i changed the bulb it doesn't do it any more...
i just put a brand new alt in hte car it was bad. i havent tryed to change the bulb i will do that. could there be a ground some where that is crossingf the brake lghts with the turn signal??
