new vibration from steering wheel/all over...
Old Apr 22, 2009 | 11:03 PM
ryleynoyes's Avatar
ryleynoyes
Exclamation new vibration from steering wheel/all over...
i just installed a mopar performance pcm, and wanted to test the new performance. so i did a couple fairly hard launches (4000 or less with fairly easy clutch let off, not a 4000 clutch DROP). no problems...
today, i was driving it, and did just a small one (about 2000 launch or so, again, not dropping the clutch, just a nice quick let out), and it started vibrating more noticeably
my neon has always vibrated, as i have the motor mount inserts, and the mopar performance bobble strut. but this is something different than i've noticed before.
it's really bad around 2500-3000 rpm, and i feel it through the steering wheel, the dash, and pretty much everywhere.
any ideas? i'm kind of thinking front motor mount...
Old Apr 22, 2009 | 11:18 PM
sabin420's Avatar
sabin420
Snapped the front motor mount..I've snapped 3 of em.
Old Apr 22, 2009 | 11:20 PM
ryleynoyes's Avatar
ryleynoyes
how obvious would the break be? i looked at it as best i could from the front and it didn't look broken... also, where would it be most likely to break at?
Old Apr 23, 2009 | 10:04 PM
sabin420's Avatar
sabin420
right under the starter where it bolts flat against the side of the motor.
Old Apr 25, 2009 | 12:01 AM
ryleynoyes's Avatar
ryleynoyes
so i just started getting a code 25 (idle air control circuit, idle on within plus or minus 200, something else) which explains my engine not running well while cold, but as this is a new occurance, would this have anything to do with my vibration? i doubt it, but just asking...
also, it seems like my steering wheel isn't aligned well anymore, it's close, but it's just off center, and seems to move a bit.
all of my vibration stuff started after a hard launch, as i said in my first post. i also made a REALLY hard left turn just after that. would that have been enough to shift something enough to vibrate?
